Using SSH into outside interface
ctasher
Community Member
Is SSH available as freeware?
I believe that the only way to get into the outside interface on a pix us to use SSH.
TIA
thiland
Level 8
Level 8
Many people use a freeware Windows SSH client called PuTTY.
You can obtain it here:
http://www.chiark.greenend.org.uk/~sgtatham/putty/
Most Linux distributions have an ssh client (OpenSSH) included.
It is possible to use telnet on the PIX as well, but not recommended for obvious security reasons.
Remember to setup SSH you need:
a hostname
a domain name
create the rsa keys
save the rsa keys
add the command:
ssh outside
-Tanner
ctasher
Community Member
Tanner...OK, I have generated the rsa key. How do I then transfer this key to putty...or is this how it is done?
many thanks
chris
you do not need to transfer any keys. you just needto create them on the pix, ca save all, and add a ssh command for the outside interface and the ip address space from which you will be connecting
