Concentrator questions
u.naranjo
I have a 3005 Concentrator and I wonder if this situation has happened to any one.
1. I VPN from home to the office but when I change my NT password, my remote vpn connection does not work any more
2. Created another group and was able to VPN but I can not ping anything even though I got the right IP address from the NT DHCP server
Does anybody have any ideas why this happens?
Thanks a bunch,
Uriel.
drolemc
Level 6
Level 6
With reference to your second problem, it could be due to name resolution issue on your Windows network. FOr more information you could refer to http://www.cisco.com/warp/public/471/vpn-net-hood.html#ping
ram.vijay
For your 1st problem, if you are using NT database to authenticate users, Check whether the password changes by clients gets dynamically updated in the NT server database?
Also, In DHCP server ip leasing environoment, check whether the DHCP server passes the info to the DNS and gets updated. But I wonder why IP communication doesn't work...
Rgds,
Vijay V
