IPSec group name and password which u define on
the concentrator is nothing but the preshared key.
The same IPSec group name and password needs to be
defined in the client for successful authentication.
To put in the client configuration go to
vpn dialer,select the connection entry ---options--
--properties---select authentication page , there
you are at the right place
