06-03-2004 11:21 AM - edited 03-09-2019 07:37 AM
WebVPN works fine. However, when running a certain application from our Microsoft SBS 2003, I get Java errors and certain pages won't open. The application is using Java 1.4.2 and we are using a VPN Concentrator 3005. Does the 3005 have backwards Java compatibility?
06-07-2004 10:11 AM
Look over the following URL and make sure you have the Javascript enabled correctly for the Internet Browser you are using.
06-08-2004 06:46 AM
We're using Netscape 7.1 and IE 6.0. What are the Javascript settings for these browsers?
06-09-2004 07:46 AM
The application we are attempting to run uses port 8080. Do I need to do a "Port Forwarding" to allow users access to the application? If so, what port should it be redirected too?
06-07-2004 10:52 AM
If it is a Java applet there will be issues. Correct me if i'm wrong, but WebVPN does not support java rewriting.
We cannot use WebVPN w/ citrix because of this. Though they are looking into it.
