WEBVPN Java RDP-Plugin Problem
d.eberwein
i have a problem with the RDP-Plugin on the WEBVPN Portal Page.
On some PCs the RDP-Plugin starts with ActiveX and on the other PC with Java. But on some PCs the Plugin starts in a really little window, which i can't resize. Is there an adjustment on the Internet Explorer or on the ASA to not have these problems?
Thanks.
owillins
Level 11
Level 11
Use the following docment Cisco Security Appliance Command Line Configuration Guide, Version 8.0 (Go through the section Installing Plug-ins Redistributed By Cisco )
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/webvpn.html
Did this resolve the issue? I have the same problem, but I thought it was related to Java 1.6.
