what cable use for between firewall to router
pkchiwing
I am beginner for use Cisco firewall, I got a cisco 1750 router with adsl card to connect to internet, and I also got cisco pix 515 firewall, but I dont know what cable(patch or crossover) I use between router to firewall and firewall to my PC?
Also I have question about configure about firewall. my router is configure dhcp, I dont know how firewall to know the IP address from router and firewall give ip address to my PC(I only need DHCP, I dont want static IP). have anyone have any sample or website?
I can post more my config in here, hope anyone can help me. Thank you
paddyxdoyle
Level 6
Level 6
The PIX 501 has a four port switch built in so PC to Firewall will be straight through CAT5.
Between the PIX outside interface and the routers interface you will need a cross over cable.
Personally i would configure the PIX as the DHCP server which will allocate IP addresses to your internal PCs and create a static subnet between the PIX and the router so you router always has the same IP address. This is essential as the PIX needs to know this address as it will always be the default gateway for the PIX
e.g.
PIX
# ip address outside 192.168.1.1 255.255.255.252
# route outside 0 0 192.168.1.2
# interface ethernet0 100full
# ip address inside 10.0.0.1 255.255.255.0
# dhcpd address 10.0.0.2-10.0.0.254 inside
# dhcpd dns
# dhcpd lease 3000
# dhcpd enable inside
Router
# interface fast Ethernet 0/1
# description To LAN (PIX)
# ip address 192.168.1.2 255.255.252
# speed 100
# duplex full
PJD
I following your method, I feel it is better but still doesnt work, I post my router and firewall config let you see what is wrong.
1750 router configuration:
version 12.2
hostname Cisco1750
logging queue-limit 100
enable secret xxx
enable password xxx
ip subnet-zero
no ip source-route
ip name-server 195.16.16.1
no ip bootp server
interface ATM0
no ip address
no ip proxy-arp
no atm ilmi-keepalive
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode auto
interface FastEthernet0
ip address 192.168.1.2 255.255.255.0
no ip proxy-arp
ip nat inside
speed 100
full-duplex
no cdp enable
interface Dialer1
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname myusername
ppp chap password 0 mypassword
ip nat inside source list 1 interface Dialer1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
access-list 1 permit 192.168.1.0 0.0.0.255
dialer-list 1 protocol ip permit
no cdp run
line con 0
speed 115200
line aux 0
line vty 0 4
login
no scheduler allocate
end
515 pix firewall configuration:
PIX Version 5.2(5)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
hostname Cisco515pix
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 1720
fixup protocol rsh 514
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
names
access-list ping_acl permit icmp any any
access-list acl_out permit icmp any any
pager lines 24
logging on
no logging timestamp
no logging standby
no logging console
no logging monitor
logging buffered debugging
no logging trap
no logging history
logging facility 20
logging queue 512
interface ethernet1 100full
interface ethernet2 shutdown
mtu outside 1500
mtu inside 1500
ip address outside 192.168.1.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
no failover
failover timeout 0:00:00
failover poll 15
failover ip address outside 0.0.0.0
failover ip address inside 0.0.0.0
arp timeout 14400
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
access-group ping_acl in interface inside
route outside 0.0.0.0 0.0.0.0 192.168.1.2 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:00:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:00:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
no floodguard enable
no sysopt route dnat
isakmp identity address
telnet timeout 5
ssh timeout 5
dhcpd address 10.0.0.2-10.0.0.2 inside(it cant let me more then 10.0.0.2)
dhcpd dns 195.16.16.1
dhcpd lease 3000
dhcpd enable inside
terminal width 80
Cryptochecksum:xxx
