Scripting DUO with PowerShell
Oldtrekky
I have a PS script that downloads the installer from "https://dl.duosecurity.com/duo-win-login-latest.exe" and sets
$installerPath = "$env:TEMP\duo-win-login-latest.exe"
I have tried 3 following different ways but each always gives a return code of 0, but the program has not actually run. (I test for the existence of the DUO Security registry entry here: "HKLM:\SOFTWARE\Duo Security\DuoCredProv")
$run_version=1
$duo_normal_setup_args = "/QUIET /RDP_ONLY=yes /IKEY=$ikey /SKEY=$skey /HOST=$apiHost"
switch ($run_version) { 1 { Write-Host "Normal processing v1" $duoprocess=Start-Process -FilePath $installerPath -Wait -PassThru -ArgumentList ` "/QUIET", ` "/RDP_ONLY=yes", ` "/IKEY=$ikey", ` "/SKEY=$skey", ` "/HOST=$apiHost" $instcode=$($duoprocess.ExitCode) } 2 { # 2nd way Write-Host "Normal processing v2" $duoprocess= Start-Process -FilePath $installerPath -ArgumentList $duo_normal_setup_args -Wait -Passthru } 3 {# 3rd way Write-Host "Normal processing v3" & $installerPath /ArgumentList $duo_normal_setup_args /Wait /Passthru *> "$env:TEMP\duo_install_log.txt" } } }
I suspect I am not passing the arguments correctly (single string or multiple strings). I have validated all the variables and they have the correct values. I have run the installer manually and it worked for one user but I need to re-do it several more times for other users. I would appreciate any suggestions or corrections.
6 Replies 6
DuoKristina
Did you compare your options and syntax to the PowerShell example in https://help.duo.com/s/article/1090 ? You might want to read through that closely.
Duo, not DUO.
Since my previous post, I discovered that I should not have the / symbols before the arguments (except for /S /qn and /V So they now look like this (with the "xx"s replaced with actual values):
/S /V" /qf RDP_ONLY="#1" FAILOPEN="#1" IKEY="DICxxxxx" SKEY="xxxxxx" HOST="xxxxxxx" FAILOPEN="#1""
And yes, I have compared every argument. They work perfectly when executed from the command line, but when run in a PowerShell script, the installer just displays the MSIEXEC parameter rules in a window, then exits with NO return code (yes, it actually empty, not 0). Checked with this:
if ($instcode -eq 0 -or $instcode -eq "")
					{Write-Output "retcode 0 or empty"
					exit 1}
There is no MSI log. I suspect it has something related to PS parameter passing and the DUO requirement of /V" with "quoted" strings inside.
Oldtrekky
I looked at the DUO docs and saw a comment that there is no longer an installer .MSI file. Just the .EXE files. Has anyone gotten the .EXE installer to work from inside a PS script?
MSI's exist here: https://duo.com/docs/checksums#unified-x86-x64-installer  , along with the group policy stuff you'd need.
I suspect if you run the exe with the command line you'll have better luck...or use the MSI, and control it with GPO (which is what we do for workstations)
Here's my command line that I push to servers.   Note the list of quoted things are wrapped in quotes.
%PATHTOFIXES%duo-win-login-latest.exe /S /V" /qn IKEY="##ikey##" SKEY="##skey##" HOST="api-xxxxxxx.duosecurity.com" AUTOPUSH="#1" FAILOPEN="#1" SMARTCARD="#0" RDPONLY="#0""
Oldtrekky
I finally got my parameters properly quoted, etc. in PowerShell for the script to accept them and start the installation GUI. But when it gets to the screen asking about proxies (which we don't use) and I click on "next", it gets error 12005 (cannot reach the authentication server). I have several users and I want to automate the process to make sure they are all done identically. I have done 2 manual installs that worked.
Oldtrekky
I got the MSI GUI to accept my parameters from my Windows PowerShell script and it began working on the installation, then failed with error 12005 (cannot reach the authentication server). I have only been doing this while on the end-user's PC via Windows Remote Desktop. Is there some requirement that the installation be done while physically present on the target machine when the MSI is run from a script? I've looked at the installation log and haven't seen anything that leads to the error. Has anyone had success with my scenario (PS script + RDP)? The userid where I am doing the installation is an admin user.
