cps-wireless
mirjetapinky
Community Member
Hey everyone! I’m trying to connect to the Wi-Fi at Cromwell High School and could really use a hand. Does anyone happen to know the username and password for cps-wireless or the password for cps-guest? I would greatly appreciate it. Thanks a ton!
If it's a school-managed Wi-Fi network, the credentials are usually provided by the school's IT department or administration. I'd recommend asking the front office, a teacher, or the IT help desk—they should be able to give you the correct login details or guest access if you're eligible.
