BYOD Onboarding without SCEP
ahurtadove
Hi community,
I was asking myself, can I configure single SSID BYOD Onboarding without SCEP? I'm in this position where I want the users to connect and register their own devices using MSCHAP as inner method but I don't want to provide certificates with SCEP as this is a platform I don't have access to.
It might be losing the whole purpose of BYOD but I just need users to register and de-register their own devices taking the MAC Address administration burden out of IT.
Thanks in advance
waynesymes
Hi Antonio,
ISE does support BYOD with EAP-PEAPv0 MSCHAPv2 or EAP-TLS profiles. You can build a supplicant provisioning profile to do only PEAP for the supported platforms (Windows, Android, MacOSX and iOS).
7 Replies 7
waynesymes
Hi Antonio,
Thank you Wayne, I will definitely try it out during this week.
No access to the blog post, is it just me?
Is it possible to post the pdf?
Cheers
Can't access either
Check it out now
Indeed it worked.
I even took out the whole Google Play procedure by going into Administration -> Settings -> CLient provisioning (left side pane) and changed "Native Supplicant Provisioning Policy Unavailable" to "Allow Network Access"
Didn't know this was possible.
Thank you
