Hi everyone,
I am a new member in this community. One of the issues I am facing with Network Switch IE-3300 (Serial No: FCW2835Y2RJ) made me the part of this community. I am not able to configure this switch using Network ports. Then I connected with serial port and received the following underlined:
Switch: flash_init
Error: Command "flash_init" not found
Switch: Write erase
Error: Command "Write" not found
It will be appreciated if someone having similar kind of issue with mentioned switch can give a clue to resolve the problem.
Nadeem Ashraf
