PacerX
Level 3
Level 3
Recently I received a Meraki MS120-8LP after attending a Webinar and was excited to try it out with our network. Our main office already had 7 MR52 APs but the APs were connected to our Cisco 2960-X. I moved them to the new MS120 but ran into an issue of having incorrectly setting the VLan when setting static IPs for the APs. After reviewing the community I came across the information needed to correct this. The 7 APs are now running off the MS120 and I was excited to see how the topology works with the added switch. We are hoping to move our main office a MX100 with next years budget. Should be exciting.
11 Comments
Welcome to the Project Gallery!
This is a place for Cisco customers and partners to share stories about their technology projects.
Use the comment section to ask a question, make a suggestion or just say well done. If you like a project, thank the author by clicking the Helpful button at the end of the post!
Did you complete a deployment recently? Share your great work with fellow community members! No project is too big or too small.
