fp_netfilter_pre_routing and net_ratelimit Kernel Errors
ServicePros
Hey Everyone,
Newer to the RV340, but I've been trying to track down a internet connectivity issue. I keep seeing the following in the event logs. Any ideas? Thanks!
2020-Nov-20, 13:42:34 EST
warning
kern
kernel: [ 2351.651681] fp_netfilter_pre_routing: 10 callbacks suppressed
2020-Nov-20, 13:42:28 EST
warning
kern
kernel: [ 2345.916506] fp_netfilter_pre_routing: 42 callbacks suppressed
2020-Nov-20, 13:42:26 EST
warning
kern
kernel: [ 2343.660080] net_ratelimit: 6 callbacks suppressed
2020-Nov-20, 13:42:23 EST
warning
kern
kernel: [ 2340.655677] fp_netfilter_pre_routing: 18 callbacks suppressed
2020-Nov-20, 13:41:52 EST
warning
kern
kernel: [ 2309.837910] fp_netfilter_pre_routing: 12 callbacks suppressed
2020-Nov-20, 13:41:31 EST
warning
kern
kernel: [ 2289.345937] fp_netfilter_pre_routing: 14 callbacks suppressed
2020-Nov-20, 13:40:26 EST
warning
kern
kernel: [ 2224.176865] fp_netfilter_pre_routing: 2 callbacks suppressed
2020-Nov-20, 13:39:25 EST
warning
kern
kernel: [ 2163.094997] fp_netfilter_pre_routing: 16 callbacks suppressed
2020-Nov-20, 13:39:10 EST
warning
kern
kernel: [ 2147.882400] fp_netfilter_pre_routing: 2 callbacks suppressed
2020-Nov-20, 13:38:45 EST
warning
kern
kernel: [ 2122.656127] net_ratelimit: 4 callbacks suppressed
2020-Nov-20, 13:38:44 EST
warning
kern
kernel: [ 2121.906400] fp_netfilter_pre_routing: 40 callbacks suppressed
2020-Nov-20, 13:37:32 EST
warning
kern
kernel: [ 2049.686272] fp_netfilter_pre_routing: 14 callbacks suppressed
2020-Nov-20, 13:37:04 EST
warning
kern
kernel: [ 2021.703825] net_ratelimit: 7 callbacks suppressed
10 Replies 10
Mark Elsen
                         - Not sure about the cause , but make sure to use the latest firmware available.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Yeah the device is on the latest firmware. I'm newer to the Cisco platform and my issue that I'm having a hard time finding explanations for the event log errors. I wish they included more information. Are there any online resources that you know of to help? The device is only a few months old, is it still under support?
Thanks, Jim
  - The error may relate to heavy or high traffic , as an example link below denotes. If possible try to monitor traffic volumes, that the device has to handle.
                                            https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvg29701/?rfs=iqvred
  M.
       Beauty and terror
      Just keep going
       No feeling is final
That's odd because there was nobody there during this time. Could this be
causing internet connectivity issues and what should I do? Should should I
limit download bandwidth or something to that nature? I guess what I'm
asking is this causing a problem? Thank you
                          - If no-user/app problems are seen, then the error could be bogus (bug) and considered unimportant.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
kernel: [719422.165430] FIREWALL SYN-FLOOD:IN=eth2 OUT= DST_MAC=3c:57:31:84:a8:f5 SRC_MAC=:4a:1d:70:d0:81:41 SRC=87.251.70.79 DST=96.94.47.181 LEN=40 TOS=0x00 PREC=0x20 TTL=226 ID=123 PROTO=TCP SPT=65532 DPT=5746 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0xff00
2020-Nov-19, 18:07:20 GMT
warning
kern
kernel: [675940.536152] fp_netfilter_pre_routing: 42 callbacks suppressed
 - The device seems to be under syn-flood attacks ; here are some links on how to mitigate with them :
          https://community.cisco.com/t5/security-documents/how-to-prevent-an-outbound-tcp-syn-flood-attack-on-the-edge/ta-p/3115686
         https://community.cisco.com/t5/security-documents/how-to-configure-the-router-to-minimize-a-denial-of-service-dos/ta-p/3117624
 M.
       Beauty and terror
      Just keep going
       No feeling is final
you can't do that on RV series routers
natcomms
Has anyone found a solution? It happens 1-2 times every week. This is a huge problem for my customer when they're trying to make CC transactions for book appointments.  I'm very close to replacing the RV340 with something else.
yagnesh
kernel: [ 5094.150150] fp_netfilter_pre_routing: 8 callbacks suppressed
I try to everything but this error not gone, i try to update latest firmware, try to reset router, upgrade my ISP 1gbps and many more...till error is again and again...
Please let me know if you find solution....
