Issue with port forwarding on RV042G
Sbink
I couple of days ago I noticed that my communications coming in with port forwarding were being blocked.  I had inherited this position and had no access to the router, so I did a factory reset on it.  I have added the port required under setup-forwarding but the port still is closed.  Is there some other setting I am missing to enable port forwarding or is it possible that the router is failing?  I did a firmware update on it after I did the factory reset.
Jitendra Kumar
Martin Aleksandrov
