RV016 - Problem upgrading firmware
Curtis DeHaven
I've downloaded the file "RV0XX-v4.1.0.02-tm.bin" from Cisco's web site. The current firmware in the RV016 router is V3. I log into the router with IE9 (or even firefox), navigate to the system management section, upgrade firmware tab. Browse to the file above and click the button to upgrade. Nothing happens for a few seconds, then the browser displays cant load this page. (Same results if I use the file "RV0XX-v4.1.1.01-sp.bin" as well.) Any thoughts?
Many thanks! -- Curt
rocater
Level 3
Level 3
Hello Curtis,
The v4 firmware is for use with the v3 hardware of the RV016. You can verify this by checking the model number listed on the router itself. (it will be listed as RV016v3)
Wizard4777
mine is v2
