RV082 not optaining static IP via DHCP from ISP
ger.somers
RV082 Firmware Version: 2.0.2.01-tm
I have a RV082 set up with two wan connections
WAN 1 Cable modem with a static IP supplied by the isp via DHCP to the routers mac address, RV082 is set to Automatically Obtain
WAN 2 DSL modem with a static IP where the IPs are entered into the router manually.
The router was working fine until last weekend.
The router is now not picking up the dynanmically supplied static address from the ISP.
If I  plug in a laptop in place of the router, I get an  IP address (not the static one) and the internet works fine.
The manually entered IP is working fine.
If I change the mac address of the WAN port the router will pick up a ip address (but not the static one) and works fine.
Is anyone aware of an issue with the RV082 using a dynamically supplied Static IP address on its WAN ports.
The ISP denies any issue at thier end.
Many thanks
Ger
0 Replies 0
