날짜: 08-30-2011 06:28 PM
Hi all,
I have a Cisco Small Business Pro SRP 527W that I use for our office. Most laptops connect with no problems, but I've had others that can't see it at all.
I'm also experiencing problems with my own laptop, which is the businesses primary machine. It's a MacBook Pro running OS X Lion.
I'm also going to post on the Apple Support forum, because it may be the computer at fault. However it is only having problems with this network, and others have also been unable to connect.
For this particular computer, the problem is timing out when trying to connect.
The very odd solution I've found is to turn off wifi, plug in ethernet, then turn wifi back on. Not sure what's going on there.
날짜: 08-31-2011 01:05 AM
Hi Simon,
Thanks for using the Cisco Support Community.
We have users here at Cisco using Lion with the SRP without issue. Could you let us know what wireless settings you are using please?
Are you using WPS, or just manual configuration?
Also, which firmware release are you using?
Many thanks,
Andy
날짜: 08-31-2011 09:21 PM
Thanks so much Andrew,
I'm using WPS with WPA2 security. As for firmware release, I'm not sure sorry. How do I find that out (and update it?)
날짜: 09-01-2011 04:27 AM
Hi Simon,
You can see which release you are running from the initial log-in page (on the left hand side). When you are logged in, you can also click on the "about" button in the top right hand corner of the page.
When you log in, make sure that you use admin/admin, rather than cisco/cisco for the credentials. You will then be able to upgrade using the Administration > Firmware Upgrade menu. Grab the latest firmware from www.cisco.com/go/srp500 and follow the "Download Firmware" link on the right.
Regarding the wireless issue. Have you tried associating with the SRP by manually configuring the WPA2 shared secret for the cisco-data SSID?
Andy
새로운 아이디어를 발견하고 저장하세요. 전문가 답변, 단계별 가이드, 최근 주제 등 다양한 내용을 확인해 보세요.
처음이신가요? 아래 팁들을 확인해 보세요. 시스코 커뮤니티 사용하기 새 멤버 가이드
