As Path Filtering
Cisco-Spider
Community Member
I am receiving a BGP global routing table. I want to filter all of them and only allow with the following AS Numbers.
example:
1234 1111
1234 2222
1234 3333
1234 4444
1234 5555
1234 6666
Please help me.
2 Accepted Solutions
1234 2222
1234 3333
1234 4444
1234 5555
1234 6666
Sounds like you want to accept only the AS Paths of 1234 and or [1111,2222,3333,4444,5555,6666]
R1---->ISP1
ip as-path 1 permit ^1234_1111$
ip as-path 1 permit ^1234_2222$
ip as-path 1 permit ^1234_3333$
ip as-path 1 permit ^1234_4444$
ip as-path 1 permit ^1234_5555$
ip as-path 1 permit ^1234_6666$
router bgp 1
neighbor x.x.x.x remote-as x
neighbor x.x.x.x route-map FILTERME in
route-map FILTERME permit 10
match as-path 1
which is described in case 2 in my post above !
8 Replies 8
lgijssel
Level 11
Level 11
not much information.
Yeah, reading is difficult or would you perhaps like us to write it out for you?
Your issue seems to be about filtering prefixes with a certain path list which is described in the link as follows:
Only Allow Networks That Have Passed Through AS 4 to Enter AS 3
If you want only the networks that have passed through AS 4 to enter AS 3 from Router 3, you can apply an inbound filter on Router 3.
ip as-path access-list 1 permit _4_
router bgp 3
neighbor 2.2.2.2 remote-as 1
neighbor 2.2.2.2 route-map foo in
route-map foo permit 10
match as-path 1
Marwan ALshawi
your question not very specific !
- do you want the AS path to be match based on the existence of the above AS numbers in the path
for example any AS path has 1234 1111 in it
- or do you want to the AS path to be exact match
for example only route with AS path 1234 1111
for case 1 you can use AS path like _1234_1111_
for case 2 you can use AS path like  ^1234_1111$
hope this help
if helpful Rate
1234 1111
1234 2222
1234 3333
1234 4444
1234 5555
1234 6666
R1---->ISP1
router bgp 1
match as-path 1
Thank you very much. This is what i am looking for.
And even in my post, scenario 4
Only Allow Networks Originated from AS 4, and ASs Directly Attached to AS 4, to Enter Router 1
Thnx4notrating
Leo
