Client VPN using WAN2
GaryShainberg
Level 3
Level 3
Anyone found a way to allow all the inbound client VPN traffic to terminate on the WAN2 port of an MX.
I am sure you used to be able to do this but can not find the option.
And I being thick or has this been removed?
TIA
CTO & Solutioneer
CMNA, CMNO, ECMS2
SNSA, SNSP
~~If you found this post helpful, please give it kudos. If my answer solved your problem, click "accept as solution" so that others can benefit from it.~~
JeromeA_23
Level 3
Level 3
Hi @GaryShainberg
I think you will need to set WAN2 as primary link to do so.
JeromeA_23
Level 3
Level 3
Hi @GaryShainberg
