DSLW command...
Eloy Pascal
Level 2
Level 2
If the following is true...
The following is sample output from the show dlsw circuits command:
Router# show dlsw circuits
Index local addr(lsap) remote addr(dsap) state uptime
4060086272 4000.0000.0056(F0) 4001.0000.0049(F0) CONNECTED 00:00:13
Total number of circuits connected: 1
The following is sample output from the show dlsw circuits command with the detail argument:
Router# show dlsw circuits detail
194 0800.5a9b.b3b2(F0) 800.5ac1.302d(F0) CONNECTED 00:00:13
PCEP: 995AA4 UCEP: A52274
Port: To0/0 peer 172.18.15.166(2065)
Flow-Control-Tx SQ CW:20, Permitted:28; Rx CW:22, Granted:25 Op:
IWO
Congestion: LOW(02), Flow Op: Half: 12/5 Reset 1/0
RIF = 0680.0011.0640
And...
I have a server (local mac 4000.0000.0056) pointing at remote mac 4001.0000.0049 with no problem at all, succesfully connected, with a remote peer with more than a week connected
Then why....
When I issue the "show dlsw circuits" or "show dlsw circuits detail" command
nothing shows up, absolutely nothing...
5 Replies 5
srimural
Level 4
Level 4
Can you post the configs and the IOS version you are running.
Srinath.M
Cable&Wireless
[email protected]
c2800nm-adventerprisek9-mz.123-11.T11.bin
version 12.3
service password-encryption
hostname VAL-METRO-01
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip cef
ip ips po max-events 100
no ftp-server write-enable
voice-card 0
no dspfarm
class-map match-any VoIP-Control
match access-group 2001
class-map match-any VoIP-RTP
match access-group 2000
policy-map ME_QOS_Child
class VoIP-Control
bandwidth 8
class VoIP-RTP
priority 2048
class class-default
fair-queue
random-detect
policy-map ME_QOS_Parent
class class-default
shape average 10000000
service-policy ME_QOS_Child
no crypto isakmp ccm
dlsw local-peer peer-id 10.52.1.9
dlsw remote-peer 0 tcp 10.0.4.39
dlsw bridge-group 1
interface FastEthernet0/0
no ip address
duplex full
speed 100
interface FastEthernet0/0.700
bandwidth 10000
encapsulation dot1Q 700
ip address 10.246.200.17 255.255.255.224
service-policy output ME_QOS_Parent
bridge-group 1
interface FastEthernet0/1
ip address 10.52.1.9 255.255.255.0
ip accounting output-packets
duplex full
speed 100
standby track FastEthernet0/0.700 15
standby 101 ip 10.52.101.6
standby 101 priority 105
standby 101 preempt
bridge-group 1
router eigrp 700
network 10.52.1.9 0.0.0.0
network 10.52.101.10 0.0.0.0
network 10.246.200.17 0.0.0.0
no auto-summary
eigrp router-id 10.52.101.10
ip classless
ip http server
no ip http secure-server
access-list 2000 permit ip any any precedence critical
access-list 2000 permit ip any any dscp ef
access-list 2001 permit ip any any precedence flash
access-list 2001 permit ip any any dscp af31
control-plane
line con 0
login local
line aux 0
line vty 0 4
login local
scheduler allocate 20000 1000
end
pciaccio
Level 9
Level 9
You only show the configuration of one side of your senario. Also you show a DLSW connection established because the remote IP and local IP see each other and the DLSW protocol is talking to both end points, however the actual non routable traffic (SNA, other) is not established. You probably need to activate the remote end host systems (Activate the addresses and or major nodes on both ends). This will establish your DLSW circuits....
You probably need to activate the remote end host systems ... it is activated at both ends, that is what I don't understand!
Can you please provide the output for the following commands:
SHOW DLSW PEERS
SHOW DLSW CIRCUITS
SHOW DLSW REACHABILITY
SHOW BRIDGE-GROUP VERBOSE
SHOW DLSW LOCAL-CIRCUIT
I will not ask you for any debugs results for now. Just show us these results and lets see what we see...Thanks...
