EoMPLS & etherchannel
Antonio_1_2
Level 5
Level 5
When EoMPLS packet goes over Etherchannel link than (as I can remember) algorithm for loadbalance hashning uses VC label.
So If I have only one VC than only one link will be used (even though this VC transports a huge amount od src and dst IP addresses).
Is there a way to configure loadbalancing method to be IP (srcIP,dstIP) for MPLS packets (to force switch not to use MPLS labels for loadbalancing decision, i.e. for 7600, 3750 platforms or it is hardcoded)?
Thanks in advance,
A.
Philip D'Ath
Meraki Community All-Star
I don't think so.
http://www.cisco.com/c/en/us/td/docs/routers/7600/ios/15S/configuration/guide/7600_15_0s_book/channel.html#pgfId-1051808
EtherChannel load balancing can use MPLS Layer 2 information
Thanks you.
regards,
A.
