Help for e1 controller
midhungopi
Frequent Visitor
Frequent Visitor
helloo...
Can any help me in gettin the command for manually detecting the e1 controller in 2600
Regards...
Midhun
pkhatri
Level 11
Level 11
I'm not quite clear on what you are after. If you install an E1 card in a 2600, it should recognise it automatically. What exactly is the problem you are experiencing here ?
Paresh
Hii..
Thanks for u r reply..actually smtime back older ios it was needed to issue a command 2-3 words i guess to detect the e1 controller ..i had done the sm tim back but now i am not remeberin it anymore
Ok, the command is 'card type {t1 | e1} slot'
Paresh
Hiii..
Thanks a lot..
Its the one i needed..
Regards..
Midhun
