12-02-2021 02:43 PM
I've been looking into HTTPS inspection on Meraki MX's recently.
I found a thread from 2019 indicating that the feature came into Beta firmware and the following document released
https://documentation.meraki.com/MX/Content_Filtering_and_Threat_Protection/HTTPS_Inspection
However the doc now seems to be behind a Meraki login (separate from dashboard/community login).
Has the doc been removed from public access or am I just doing something silly?
And is the feature available in current stable or beta firmware or has it since been removed?
Solved! Go to Solution.
12-02-2021 05:42 PM
I'm under the assumption that this might be removed/no longer available. The HTTPS feature on the MX's caused severely degraded throughput once enabled plus an array of other issues.
I think the direction now going forward will be to perform the HTTPS/TLS decryption by a SASE security service like Umbrella in-line between the MX and the Internet/SaaS traffic. If you have a look at the updated Sizing guides this also seems to be the "recommended" approach. (https://meraki.cisco.com/product-collateral/mx-sizing-guide/?file).
This isn't necessarily a bad thing. SASE security architectures allow for the same security posture and enforcement to be maintained no matter the user's location. This would effectively mean that their HTTPS/TLS traffic would be still decrypted when either on a trusted network or on an un-trusted/un-managed network. Most vendors are now taking this approach to security.
12-02-2021 04:10 PM
@Brash : I think we still dont have any announcement on this feature yet. Yes i am getting the same login as well.
12-02-2021 05:42 PM
12-02-2021 06:23 PM
I thought that might be the case given MiM for HTTPS inspection is beginning to get steered away from.
That said another service means another additional cost 😞
12-03-2021 01:45 AM
Unfortunately, this is the same for all other vendors as everything moves to SASE or "Cloud delivered". There are some fantastic BUNDLE offers on Meraki + Umbrella at the moment and I'd assume these will only get better over time.
