ip host command clarification
cisco-blue
Level 2
Level 2
ip host hostname port IP
can i get the clarification of this ,
if any document relating
Jon Marshall
The ip host command simply maps a name to an IP address so
ip host TEST 192.168.5.10
you can now either type
ping 192.168.5.10
or
ping TEST
and they should both work. Note that they are local to the router you are on. See this link for full details -
ip host command reference
Jon
Giuseppe Larosa
the command reference is here
http://www.cisco.com/en/US/docs/ios/ipaddr/command/reference/iad_ip.html#wp1012102
the TCP port option is used on terminal server to map a name to the reverse telnet of an async line
see
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_configuration_example09186a008014f8e7.shtml#configs
Hope to help
Giuseppe
