IPsec VTI setup using C9300
Yamen Yip
Frequent Visitor
Frequent Visitor
I am wondering why I cannot find there is a command option for
tunnel mode ipsec ipv4
during I setup a simple IPsec tunnel ? Can anyone help? Thank you.
Switch Ports Model SW Version SW Image Mode
* 1 41 C9300-24P 16.12.4 CAT9K_IOSXE INSTALL
Technology Package License Information:
Technology-package Technology-package
Current Type Next reboot
network-advantage Smart License network-advantage
9300-2(config-if)#tunnel mode ?
gre generic route encapsulation protocol
mpls MPLS encapsulations
sdwan SDWAN Overlay
tag-switching IP over Tag Switching encapsulation
crypto isakmp policy 1
encryption aes 256
hash sha256
authentication pre-share
group 2
lifetime 30000
crypto isakmp key xxxxxxx address 0.0.0.0
crypto isakmp keepalive 10
crypto ipsec transform-set vpn-transformset esp-aes 256 esp-sha256-hmac
mode tunnel
crypto ipsec profile vpn-VTI
set transform-set vpn-transformset
interface Tunnel0
ip address x.x.x.x 255.255.255.0
tunnel source x.x.x.x
tunnel destination x.x.x.x
tunnel protection ipsec profile vpn-VTI
end
Giuseppe Larosa
Hello @Yamen Yip ,
I don't think that IPSEC tunnels are supported in a Catalyst switch like C9300.
The commands can be present in the CLI parser but the device lacks an hardware based encryption / decryption engine for IPSec and so it should not be able to put user traffic over it.
There have been other similar threads the issue is that IOS XE CLI is so "unified" that allows you to issue commands not supported in this specific platform.
You will need a router for this.
Hope to help
Giuseppe
6 Replies 6
Giuseppe Larosa
Hello @Yamen Yip ,
Hope to help
Giuseppe
I was thinking like you, but reading the C9300 datasheet, and we can see that It may be supported:
IPSec encryption delivers secure end-to-end encrypted traffic between sites and connectivity to the Cloud. C9300X models support line rate IPSEC up to 100 Gbps delivering uncompromised secure connectivity.
So, I really want to know if it is supported or not !
Regards.
Philippe Hermoso
                                       >...So, I really want to know if it is supported or not !
   - I don't think so , attached   you will find the output of the feature navigator  https://cfnng.cisco.com/browse/routing/features
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
This is the point!
francisco14
Frequent Visitor
Frequent Visitor
The
tunnel mode ipsec IPv4
command does not exist in the SW-C9300, in the "transform set" configure it in tunnel mode as you did, in the interface you put
tunnel mode GRE IP
and your traffic will be encrypted
sorry for my bad English
You dip stick, never apologise for this.
Your English is infinitely better than my - any other language, because I do not have one.
