lisp protocol
you57
Hello, I would like to set up the lisp protocol on a c3725 router under GNS3,
but the problem I cannot access in lisp configuration mode.
If I type the command router I cannot find the lisp mode.
I have installed several versions of router. Could you help me ? Thanks in advance.
mlund
Level 11
Level 11
I was playing around with lisp a little +15 years ago. I can't remember for shure, but I think I was using gns3. But I was using 7200 routers. Give them a try and see if they have support.
/Mikael
6 Replies 6
Supermantech
Frequent Visitor
Frequent Visitor
do you see in the documentation that this device supports LISP?  generally only devices that support SD-WAN will support lisp,  is my guess
Thanhs for your help.
Giuseppe Larosa
Hello @you57 ,
LISP is too modern feature to be present on a C3725 that is a 15 years old router.
LISP is i used on:
EIGRP OTP  Over the TOP
SD Access with DNAC
SD WAN
It requires IOS XE devices running at leat  IOS XE 17.x code.
Hope to help
Giuseppe
thanks so much
mlund
Level 11
Level 11
/Mikael
yes 7200 have lisp. Thank you.
