Load Balancing
sharosharo
Community Member
Dears,
i have a Cisco router C3900 and connected to a switch , i configured load balancing per destination ip and mac but one port has congestion and other ports too free
why load balancing is not working properly ? why not balancing between ports ?
Mark Malone
its recommended to set it as port-channel load-balance src-dst-port
This method uses both source and destination ip addresses for calculating the load balancing
Only try the change during non production hours
thanks a lot mark for your reply , i appreciate
Joseph W. Doherty
So you have a dual Etherchannel/port-channel between your switch and 3900?
On a switch, you'll want to select the hashing algorithm that uses the most "changing" attribute(s). Often src-dst-ip offers a good distribution (which I suspect was meant by Mark when he suggested srt-dst-port), but if the bulk of traffic is between the same two hosts, it will send all that traffic to the same link.
On your 3900, unless you're using a switch module that supports various hashing algorithms, you might be limited as I'm unsure hashing algorithms choices are offered with routed ports.
Understand even with the "best" hashing algorithm choice, a single heavy flow will only use one link. Also understand, hashing doesn't take into account current link loading. I.e. two heavy flows might be directed to the same link while the adjacent link is effectively unused.
