MX 26.2.1 Beta - HTTPS inspection ?!
JamesT91
Meraki Community All-Star
Security appliances software versions MX 26.2.1 changelog
Executive summary
  • This is the first beta release for MX 26.2.
  • This release further expands security capabilities to provide deeper inspection and control than ever before with new Adaptive Policy enforcement support, TLS inspection, and greatly expanded organization-wide group policy functionality.
  • Additionally, MX 26.2 brings exiting new BGP and VRF configuration options, alongside IP-in-IP and DS-Lite support. and improved support for IPv6-only connectivity. Together, this provides many new ways to configure and deploy MX appliances.
  • Please see the full details below.
What's new
  • Adaptive Policy & Security: New capabilities include IP-to-SGT mapping, SGACL support, and TLS and HTTPS inspection with IPS support.
  • Expanded Firewall Capabilities: Comprehensive Organization-wide Group Policy support, including mixed L3/L7 rule criteria, IPv4/IPv6 matching, reusable rulesets, and VLAN-based policy rules with per-rule logging.
  • Advanced Routing & BGP: Expanded IPv6-only networking support, enhanced VRF support for eBGP and AutoVPN, and new controls for BGP outbound filtering, and route preference.
  • Enhanced WAN & Connectivity: Added support for IP-in-IP and DS-Lite support for service-provider use cases.
Legacy products notice
  • When configured for this version, Z3(C) devices will run MX 19.2.7.
  • When configured for this version, MX64(W), MX65(W), MX84, MX100, and vMX100 devices will run MX 18.107.13.
Other
  • The product complies with EN 18031-1:2024 and EN 18031-2: 2024
6 Replies 6
That's the proof that reincarnation is possible ... 😉
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
Raphael_L
I wonder how much the performance hit is on classic MX vs Secure Routers
joey.debra
And I wonder if they are only going to support it outbound or in the future they will also allow the inbound port forward based decrypt - known key method.
Secondly I'm also curious if they are going to implement it in combination with org-wide group policies.
If you use org-wide on a VLAN you can't use network wide.  When you want to limit the which local VLANs will be decrypted-outbound you will need the controls to do that.
chweber2
Inbound support is a future consideration but not in the plans yet as primary demand has been on the outbound side
Regarding org-wide group policies, yes decrypt support is being added in the 27 release
joey.debra
Nice to know thanks!
Btw while I have you here.. regarding org-wide policies.  Is the content filtering feature also something that will be added to it so we can fully move towards org-wide policies instead of VLAN based network-wide group-policies?
