MX - BootP
scottchester
Community Member
Does the MX line respond to BootP requests? While we frequently think this is the same as DHCP, it is an earlier protocol. I believe DHCP still relies on bootp for some functions.
I ask because I came across some devices that while new seem to be stuck in the 80s and only support bootp. MX didn't respond to the request.
5 Replies 5
MerakiGnome
Meraki Community All-Star
Hi @scottchester , have you enabled boot options in your DHCP scope? We have this enabled and working across a number of sites as per the below setup.
Darren OConnor
https://www.linkedin.com/in/darrenoconnor
I was wondering about turning that on, but do not have it enabled currently. I don't need to provide server or file name, but I can see if it makes a change just turning it on.
MerakiGnome
Let us know how you get on @scottchester
Darren OConnor
I tried adding random info to the boot server and filename fields, but bootp still didn't seem to work. I also tried adding a DHCP server on MS with the extra fields and no change. It may just be the random 10 meg half duplex devices that don't really work right.
inderdeepsingh1
Level 11
Level 11
I dont see any issue in my environment ...
Cisco Awarded Blogs 2020/2021 https://www.thenetworkdna.com/
