MX MTBF
philippehatet
Frequent Visitor
Frequent Visitor
Hello I m looking for MTBF(mean time before Failure) of different MX appliances (67, 67W, 100, 250, 450). They are not in the datasheet. Thanks
5 Replies 5
Nydo89
Frequent Visitor
Frequent Visitor
Check this post:
https://community.meraki.com/t5/Wireless-LAN/MTBF-MR74-and-MR53/m-p/50833#M7771
COntains MTBF for 100, 250, 450.
For the rest it seems you need to contact support.
BR, Nils
raj.yarlagadda@meraki.com
Here are the MTBF values:
MX67: 515,646
MX67W: 268,886
MX100: 389,000
MX250: 336,800
MX450: 336,800
Cheers!
Raj
If you found this post helpful, please give it kudos. If my answer solved your problem, click "accept as solution" so that others can benefit from it
Hi Guys,
Could someone provide me the MTBF for MX 68 and MS 210 and is there a public document that has published MTBF for these products so that I can share with my customer.
Amit
Hello @amitgill
Unfortunately, there is no public-facing document available. However, you can always open a case with Meraki support to get this information. Please find the requested MTBF values below.
MX68: 174,600
MS210-24: 590,165
MS210-24P: 391,648
MS210-48: 439,585
MS210-48LP: 381,015
MS210-48FP: 320,555
Cheers!
Raj
Is the MTBF for the MX67C available?
Thank you
