MX67 Interconnectivity Issues
DKetchum
Community Member
We set up a MX67. It can ping and connect back to the HQ office but if we run an application hosted at the HQ then it will lag out.
16 Replies 16
aleabrahao
Meraki Community All-Star
Well, this could be happening for any number of reasons. It could be a problem with your link, it could be high usage of the box, it could be an application problem.
Do you have link balancing active? If so, have you tried to create an SD-WAN rule forcing this traffic to this specific destination and giving preference to only one of its links?
Something like this.
I am not a Cisco employee. My suggestions are based on documentation of Cisco, best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
Do I need to configure the VPN route for the device although the clients connected are directly connected? Our connection is as such: The MX is connected to a dummy switch, the clients are connected to the switch. I am thinking if we are needing to configure the traffic to go through the HQ. Is that possible?
aleabrahao
In SD-WAN, route exchange is automatic, can you show how your VPN is configured on both sites?
Are you asking for the Site-to-site VPN from the added network and also the HQ?
aleabrahao
This configuration.
Attached are the VPN configurations.
aleabrahao
It looks good, so I return to my original question, do you have two links and do you balance the links?
We are utilizing 1 link.
Philip D'Ath
Is it a "lite" application, like a web app - or is it a "thick" app like Microsoft Access?
What is the speed of your link at HQ and the spoke?
The application is SAP. It is a thick application. How can I view the speeds?
BlakeRichardson
What is the link speed, SAP is very resource hungry especially if you have a complex set up.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
HQ link speed: 1Gbps Full Duplex
Spoke: 1Gbps Full Duplex
CMR
What firmware are you running? An MX67 will not pass traffic at 1Gb/s and depending on the firmware version and features enabled it will be much less.
If my answer solves your problem please click Accept as Solution so others can benefit from it.
CMR
Also I presume you mean 1Gb/s upload and 1Gb/s download as WAN connections do not have duplex in the same way as LANs. They are usually a single fibre. If you are looking at the WAN port of the MX, that is simply the maximum speed that the port can run at and not the WAN speed.
