MX67 - Loopback configuration
jrsitar01
Frequent Visitor
Frequent Visitor
Hello all, I am turning up Meraki SD-WAN for the first time and I am not seeing anywhere to configure a Loopback 0 for monitoring. Has anyone been able to successfully do this? IF yes, can you please point me in the right direction? thank you
Sadly, there is no loop back interface on the MX. You need to use one of the data interfaces for this. If you want to send information (like RADIUS, syslog, etc) the documentation will tell you which interface will be used.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
Raphael_L
Meraki Community All-Star
Also keep in mind that MX for some / many ( all ? ) services will prefer the interface with the highest vlan ID !
