Network usage
RonW1
Community Member
We recently connected WAN2 to our MX250. I have it doing load balancing.
In Appliance Status there is a network usage graph and wanted to confirm that it showing the throughput for each WAN and not the total throughput. I know it's balancing so they should be showing the same.
So in my case peak with be 450 Mbps per WAN and not 450Mbps in total across both WAN's
Thank you
MerakiGnome
Meraki Community All-Star
Hi @RonW1 , the graph is showing the total per WAN link. WAN1 being the darker blue and WAN 2 the light blue line.
Darren OConnor
https://www.linkedin.com/in/darrenoconnor
MerakiGnome
Darren OConnor
CMR
@RonW1 indeed you have 300-400Mb on each link.
If my answer solves your problem please click Accept as Solution so others can benefit from it.
