OSPF debug message
v.nastase
Level 2
Level 2
I have a router in OSPF debug mode.
I received the message:
OSPF: Rcv packet from 10.59.229.1 src not on the same network
What it means that?
Thanks in advance for your help
Check the primary IP address on the facing interfaces on the two neighboring routers. From this message, the primary subnet on each router is not the same, which definitely prevents the adjacency from froming.
Hopew this helps,
