Performance Routing Basic Load-balancing
neil grant
Level 3
Level 3
I have a requirement to set up PFR as a load balancing mechanism for i/eBGP (LAB environment for the moment)
Topology:
              Iperf Client192.168.1.254
                                I
                                I
Primary 20Mb --------iBGP--------Secondary 5Mb
    I                                                I
    I                                                I
    I                                                I
eBGP  (PE)                                eBGP  (PE)
    I                                                  I
    I                                                  I
    I                                                  I
                                  I
                                  I
                                  I
                                  I
                  Iperf Server192.168.3.254
Now when generating TCP traffic with Iperf i only seem to be getting the 20Mb despite the prefix 192.168.3.0/24 being OOP:
Mar 11 16:51:25.675: %OER_MC-5-NOTICE: Range OOP BR 192.168.1.1, i/f Gi0/0.100, percent 28. Other BR 192.168.1.2, i/f Gi0/0, percent 0
Mar 11 16:51:25.675: %OER_MC-5-NOTICE: Exit 192.168.1.1 intf Gi0/0.100 OOP, Tx BW 5730, Rx BW 246, Tx Load 28, Rx Load 1
Mar 11 16:51:45.907: %OER_MC-5-NOTICE: Range OOP BR 192.168.1.1, i/f Gi0/0.100, percent 80. Other BR 192.168.1.2, i/f Gi0/0, percent 0
Mar 11 16:51:45.907: %OER_MC-5-NOTICE: Load OOP BR 192.168.1.1, i/f Gi0/0.100,  load 16104 policy 12000
Mar 11 16:51:45.907: %OER_MC-5-NOTICE: Exit 192.168.1.1 intf Gi0/0.100 OOP, Tx BW 16104, Rx BW 685, Tx Load 80, Rx Load 3
Mar 11 16:52:05.739: %OER_MC-5-NOTICE: Range OOP BR 192.168.1.1, i/f Gi0/0.100, percent 70. Other BR 192.168.1.2, i/f Gi0/0, percent 0
Mar 11 16:52:05.739: %OER_MC-5-NOTICE: Load OOP BR 192.168.1.1, i/f Gi0/0.100,  load 14072 policy 12000
Mar 11 16:52:05.739: %OER_MC-5-NOTICE: Exit 192.168.1.1 intf Gi0/0.100 OOP, Tx BW 14072, Rx BW 594, Tx Load 70, Rx Load 2
If someone could point out where i am going wrong it would be appreciated:
Border          Status  UP/DOWN            AuthFail  Version
192.168.1.1      ACTIVE  UP      00:08:04          0  3.0
Gi0/1          INTERNAL UP
Gi0/0.100      EXTERNAL UP
External            Capacity      Max BW  BW Used    Load Status          Exit Id
Interface            (kbps)      (kbps)    (kbps)    (%)
Gi0/0.100      Tx    20000      12000    18473      92 UP                    2
                Rx                20000      800      4
192.168.1.2      ACTIVE  UP      00:08:04          0  3.0
Gi0/0          EXTERNAL UP
Gi0/1          INTERNAL UP
Gi0/0          Tx      5000        4500        0      0 UP                    1
                Rx                  5000        0      0
Customer_PE#
key chain pfr
key 0
  key-string cisco
pfr master
max-range-utilization percent 10
logging
border 192.168.1.1 key-chain pfr
  interface GigabitEthernet0/1 internal
  interface GigabitEthernet0/0.100 external
  max-xmit-utilization percentage 60
border 192.168.1.2 key-chain pfr
  interface GigabitEthernet0/0 external
  max-xmit-utilization percentage 90
learn
  throughput
  delay
  periodic-interval 0
  monitor-period 1
holddown 90
mode route control
periodic 180
resolve range priority 1
resolve utilization priority 5 variance 20
no resolve delay
pfr border
local GigabitEthernet0/1
master 192.168.1.1 key-chain pfr
Regards Neil
Regards Neil http://uk.linkedin.com/pub/neil-grant/20/5b0/267
neil grant
Level 3
Level 3
BGP Table:
Customer_PE#show ip bgp
BGP table version is 11, local router ID is 10.173.0.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale, m multipath, b backup-path, x best-external, f RT-Filter
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
*> 10.10.10.0/30    0.0.0.0                  0         32768 i
*                   10.10.10.1               0             0 4445 i
*> 10.10.10.4/30    10.10.10.1               0             0 4445 i
*>i172.31.0.8/30    192.168.1.2              0    100      0 i
*>i172.31.0.12/30   192.168.1.2              0    100      0 4445 i
*                   10.10.10.1                             0 4445 64513 i
*> 192.168.1.0      0.0.0.0                  0         32768 i
* i                 192.168.1.2              0    100      0 i
* i192.168.3.0      192.168.1.2              0    100      0 4445 64513 i
*>                  10.10.10.1                             0 4445 64513 i
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Your fastest path only seems to have 20 Mbps, correct?
PfR, I believe, sends all flows for one of its prefixes per one path.  If true, an OOP prefix wouldn't be able to obtain more bandwidth.  If the prefix wasn't being actively managed, then ECMP could exceed one path's bandwidth for multiple flows under the same prefix.
Hi Joseph,
In this lab 20Mb is the fastest link (My eBGP neighbor) the iBGP neighbor actually hasnt got any shapping configured at the minute so is 100Mb
Ok since following your suggestion that load balancing is per prefix i have configured the following:
Topology:
                                I
                                I
    I                                                I
    I                                                I
    I                                                I
eBGP  (PE)                                eBGP  (PE)
    I                                                  I
    I                                                  I
    I                                                  I
                                  I
                                  I
                                  I
                                  I
Iperf Server192.168.3.254 / 192.168.4.254
*  10.10.10.0/30    10.10.10.1               0             0 4445 i
*>                  0.0.0.0                  0         32768 i
* i192.168.1.0      192.168.1.2              0    100      0 i
* i192.168.4.0      192.168.1.2              0    100      0 4445 64513 i
So when generating traffic at 20Mb to 192.168.3.254 at 20Mb the PFR master acknowledges the interface is OOP:
Mar 12 10:08:58.699: %OER_MC-5-NOTICE: Range OOP BR 192.168.1.1, i/f Gi0/0.100, percent 99. Other BR 192.168.1.2, i/f Gi0/0, percent 0
But still does not utilise the other link when i start a Iperf session to the 192.168.4.0 prefix
Customer_PE#show pfr master border detail
192.168.1.2      ACTIVE   UP       00:01:51          0  3.0
Gi0/1           INTERNAL UP
Gi0/0           EXTERNAL UP
Gi0/0           Tx      5000        4500         0       0 UP        2
                 Rx                  5000         0       0
192.168.1.1      ACTIVE   UP       00:01:51          0  3.0
Gi0/1           INTERNAL UP
Gi0/0.100       Tx     20000       12000     19957      99 UP        1
                 Rx                 20000         8       0
Configuration as it stands at the minute:
Customer_PE#show run | sec pfr
key chain pfr
key 0
  key-string cisco
pfr master
logging
learn
  throughput
  delay
  periodic-interval 0
  monitor-period 1
  aggregation-type prefix-length 32
holddown 90
mode route protocol pbr
mode route control
periodic 180
no resolve delay
pfr border
Customer_PE#
Regards Neil
neil grant
Level 3
Level 3
I think PFR isnt aware of the routes via iBGP: (G0/1)
Customer_PE#show pfr master  prefix
OER Prefix Statistics:
Pas - Passive, Act - Active, S - Short term, L - Long term, Dly - Delay (ms),
P - Percentage below threshold, Jit - Jitter (ms),
MOS - Mean Opinion Score
Los - Packet Loss (packets-per-million), Un - Unreachable (flows-per-million),
E - Egress, I - Ingress, Bw - Bandwidth (kbps), N - Not applicable
U - unknown, * - uncontrolled, + - control more specific, @ - active probe all
# - Prefix monitor mode is Special, & - Blackholed Prefix
% - Force Next-Hop, ^ - Prefix is denied
Prefix                  State     Time Curr BR         CurrI/F         Protocol
                      PasSDly  PasLDly   PasSUn   PasLUn  PasSLos  PasLLos
                      ActSDly  ActLDly   ActSUn   ActLUn      EBw      IBw
                      ActSJit  ActPMOS  ActSLos  ActLLos
192.168.3.0/24          DEFAULT*       95 192.168.1.1     Gi0/0.100       U
                               U
Mar 12 10:43:48.791: OER BR: Timer event, 0
Mar 12 10:43:50.231: OER BR: Timer event, 2
Mar 12 10:43:50.231: OER BR: Timer event, 2       U        0        0        0        0
                               U       10        0   500000    20384        0
                               N        N
192.168.4.0/24          HOLDDOWN       53 192.168.1.1     Gi0/0.100       BGP
                               U        U        0        0        0        0
                              12        9   500000   500000    20444        0
                               N        N
Customer_PE#
