07-20-2006 05:12 AM - edited 03-03-2019 01:23 PM
We currently have a mlppp bundle with 4 serial member interfaces connecting to a remote site. Is it possible to have the same host router have a seperate mlppp bundle with 4 serial interfaces for a seperate remote site. We are using a Cisco 3800 router.
We are using a virtual-template setup.
Can more than 1 virtual template be configured on the same router.
We are doing this config without the IPX
http://www.summa4.com/warp/public/793/access_dial/mpp_serial.html
Any suggestions would be great.
thanks
-pat
07-20-2006 05:45 AM
yes you can have the multiple MLPPP bundle on same router.
07-20-2006 11:02 AM
Thanks for your reply. Have you done it with the virtual templates? as in the example?
Except times 2.
I only ask this because it seems to me there is a problem with the virtual access interfaces correclty attaching to the correct virtual template. But I cannot find where I read this.
I cannot lab this up until a couple of weeks and was hoping that someone has done it this way.
thanks
-pat
07-22-2006 07:45 AM
I sucessfully was able to lab this up today.
