Problem Peering
matou
Frequent Visitor
Frequent Visitor
I have a problem announcing a prefix on the Internet with a new router
Here is the topology.
R1 has a BGP configuration with two ISPs with a full-view. the prefix 192.1.1.0/22 ​​is announced and this prefix is ​​well propagated on both ISPs. There is the ip route config 192.1.1.0 255.255.252.0 Null0
I just installed a new router to configure another bgp session with a Internet Exchange IX for peering.
R1 and R2 are connected in /31
R1(192.1.1.3/31) <--> R2 (192.1.1.4/31) and ospf is configured on both interfaces.
On R2, there is a default route: ip route 0.0.0.0 192.1.1.3
On R2 there is now BGP with IX, the BGP configuration is ok, and I announce 192.1.1.0/22 ​​but it does not propagate. The prefix 192.1.1.0/22 ​​is in the routing table with ospf though.
Thanks for your help.
Hi @matou ,
Your best bet at this point would be to contact the support staff at the IX and work with them to see what could be the issue.
Harold
11 Replies 11
Hi @matou ,
You are probably referring to prefix 192.1.0.0/22, right? How do you originate this prefix in BGP on R2 (redistribution, network statement)? Could you please provide the configuration you use to originate this prefix in BGP?
Harold
Hi @Harold Ritter , yes right
R2 is n9k-c93180yc
ip prefix-list BGPv4_OUT seq 10 permit 192.1.1.0/22
route-map BGPv4_OUT permit 10
match ip address prefix-list BGPv4_OUT
router bgp 654321
router-id 192.1.1.4
no enforce-first-as
address-family ipv4 unicast
network 192.1.1.0/22
redistribute static route-map BGPv4_OUT
neighbor <IP ROUTE SERVER IX>
remote-as 123456
description rs1
route-map BGPv4_OUT out
soft-reconfiguration inbound always
remote-as 123456
description rs2
Thank you
Hi @matou ,
192.1.1.0/22 is not a valid prefix. 192.1.0.0/22 is.
Can you provide the output for the following commands from R2:
show ip route 192.1.0.0/22
show bgp ipv4 uni neighbor <IP ROUTE SERVER IX> advertised-routes
Hi @Harold Ritter
192.1.0.0/22 is an exemple fictitious. The real prefix is ​​another one, It really exists.
n9k-01-XX-XX# show bgp ipv4 uni neighbor X.X.X.X routes advertised
Peer X.X.X.X routes for address family IPv4 Unicast:
BGP table version is 9568, Local Router ID is 192.1.0.3
Status: s-suppressed, x-deleted, S-stale, d-dampened, h-history, *-valid, >-best
Path type: i-internal, e-external, c-confed, l-local, a-aggregate, r-redist, I-i
njected
Origin codes: i - IGP, e - EGP, ? - incomplete, | - multipath, & - backup, 2 - b
est2
Network Next Hop Metric LocPrf Weight Path
*>l192.1.1.0/22 0.0.0.0 100 32768 i
Hi @matou ,
Thanks for the additional information. It looks like the prefix is being advertised to the IX. What is the issue then?
Harold
matou
Frequent Visitor
Frequent Visitor
Hi @Harold Ritter ,
When I do tests from outside, for example from another AS member of peering, the request goes through IP transit and not through peering. And tools like "bgp he", "bgp tools" do not add new peers.
Can the command on R1 "ip route config 192.1.1.0 255.255.252.0 Null0" have an impact on propagation ?
Thank you
Hi @matou ,
> When I do tests from outside, for example from another AS member of peering, the request goes through IP transit and > not through peering.
You need to check in this other IX member if the route is received from the IX route server and why it prefers the path through your transit provider.
I am sure how and how often this information gets updated.
No, it doesn't
Harold
Hi @Harold Ritter
Thank you for reponse,
But, the other IX member has a looking glass tool and when I do command "show ip bgp as", there are just Transit IP routes for my ISP, but not peering routes does not exist.
Hi @matou ,
Harold
matou
Frequent Visitor
Frequent Visitor
Hi @Harold Ritter
Fixed with IX support. Filtering issue on routes. Problem solved
Thank you
You are very welcome @matou and thanks for the feedback
