Programming
My guestshell would not enable on Linux
what’s the cause
7 Replies 7
svemulap@cisco.com
What are you trying to do ?
Details !!
I enable http server and iOS
And add the the virtual port group
And app vnic
I enabled the guest ip address
I enabled the default gateway
And then I enabled the guestshell but it wouldn’t work
Still missing details !!
Which version ?
Which platform ?
Is this cEdge or vEdge ?
Always good to share details, so folks can understand what the issue and try to help.
Csr 1000v series
Csr 1000v series 16.12
@kagisolebambo458 here is the guide for enabling Guestshell on your version https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/prog/configuration/1612/b_1612_programmability_cg/guest_shell.html
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
