QOS question
merryllem
Level 4
Level 4
Hello All,
This might be a silly question but i need verification. Given the configuration below
Class map realtime (match any)
match (real time voice/vid traffic)
class map important (match any)
match (potentialy bandwidth hungry applications (http/ftp - any file transfer applications))
match (managment traffic ssh/telnet)
class map bwhungryudp
match (non real-time udp video traffic)
policy map QOS
class realtime
  priority percent 40
class important
  bandwith percent 40
class bwhungryudp
  bandwith percent 10
class default
  bandwith percent 10
interface s1/0
service policy output QOS
max-reserved-bandwidth 100
The output above shows that my manangement traffic and file transfer traffic are in the same class. Is it possible for the file transfer traffic to consume the link and not leave any space for management traffic to flow? If so, would it be best to create seperate class for the management to make sure manangement traffic gets bandwith all the time?
Let me know if I'm over thinking the scenario. Any input is appreciated. Thanks.
kyukim
It is easy to create a separate class for management traffic and assign different bw.
Or, you can just remove match (managment traffic ssh/telnet) from class map important. Then, management traffic will be put into class default and get 10% BW.
KK
