radius command changes
jkeene0007
Visitor
I recently upgraded a Catalyst 3650 from 03.03.03 to 03.07.05 and the switch is no longer recognizing my radius setup.  I've pulled some info and examples of what the commands are now, and confirmed my auth and acct ports on the NPS server.  Nothing is working.
The NPS server (Windows 2012 R2) hasn't logged a single connection attempt since the upgrade.
Here are the radius lines from the switch:
aaa authentication login default group radius local
aaa authorization exec default group radius local
radius server default
address ipv4 10.10.10.61 auth-port 1812 acct-port 1813
key switch19nps
Many thanks in advance
I do not have version 03.07.05, but on 03.03.03 it works. Please try the following:
aaa new-model !Make sure you are running this command.
radius server SERVER1
address ipv4 10.10.10.61 auth-port 1812 acct-port 1813 !(default ports are udp 1646 and 1645)
key switch19nps
retransmit 10
timeout 6
OR, the other alternative is:
aaa group server radius SERVER1
server 10.10.10.61 auth-port 1812 acct-port 1813
radius-server key switch19nps
aaa new-model
aaa authentication login default group SERVER1 local
Remember to check whether you are running 'aaa new-model' before making any changes. Also, be sure to use the correct UDP ports on both the switch and the server.
HTH,
Meheretab
HTH,
Meheretab
Do you have layer 3 connectivity with the radius server? Could you ping it?
If yes, please try the following:
radius-server host 10.10.10.61 auth-port 1812 acct-port 1813 key switch19nps
HTH,
Meheretab
HTH,
Meheretab
Thanks for the suggestion, but unfortunately the command errored out at 'host'
GE-L3-07#ping 10.10.10.61
Sending 5, 100-byte ICMP Echos to 10.10.10.61, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/4/10 ms
GE-L3-07(config)#$.10.10.61 auth-port 1812 acct-port 1813 key switch19nps
% Invalid input detected at '^' marker.
key switch19nps
retransmit 10
timeout 6
aaa new-model
HTH,
Meheretab
HTH,
Meheretab
Georg Pauwen
default accounting port is UDP 1646, and default authentication port is UDP 1645, can you try those ?
You can also configure the 'automate tester' to test if the configure ports work at all....
