Remove
Uhmazing
Frequent Visitor
Frequent Visitor
6 Replies 6
Kanan Huseynli
Hi ,
https://www.cisco.com/c/en/us/td/docs/solutions/CVD/SDWAN/cisco-sdwan-design-guide.html#ControllerDeployment
this is SD-WAN CVD. You can read and create your design based on requirements. Just few tips:
vBond redundancy is easy and should be by DNS name.
vSmart redundancy is also easy, they (two vSmart) will act active/active central control plane nodes.
vManage redundancy can be done by 2 ways:
a) cluster (at least 3 option)
b) DR (disaster recovery, active/standby manual actions required)
https://www.cisco.com/c/dam/en/us/td/docs/routers/sdwan/knowledge-base/disaster_recovery_technote.pdf
For not too big deployment, and for pilot project you can follow 2nd option.
vEDGE redundancy can be done per site with the same site-id.
For Provider redundancy, you may you regular internet/mpls design where every node connected to both transport. For branches where 2 routers you can also use one router connected to internet, another router connected to mpls. You may or may not use TLOC-Extension for this site.
AFAIK, dcloud has dedicated designs. For your own design, you may create lab in EVE-NG PRO (but you need pro license and server where you can run lab).
Honestly, if you haven't done SD-WAN it will be a bit difficult, because there are many points in SD-WAN. You definitely need lab environment if proof of concept is mandatory.
Unfortunately,personally I can't create any compensation, but hope my given information will help you. Good Luck!
If you will have question, you can write in this post.
HTH,
Dhammike
Frequent Visitor
Frequent Visitor
SD-WAN POC tool in Dcloud allows you to create your own topology. If you don't have any prior expericence you may play with the below 2DC topology and create your own custom one when you are comfortable.
https://dcloud2-rtp.cisco.com/content/demo/714497?returnPathTitleKey=content-view
Any further queries, happy to assist.
HTH.
Dhammike.
thank you for the link. However, when I click on it it says the content has either been removed or I don't have access to it.
Just go to https://dcloud.cisco.com , and login with your account.  Search SD-WAN under catalogue section. You will see the SD-WAN POC tool similar to attached. You can schedule a session by going through the schedule option.
HTH..
Dhammike.
Unfortunately I cannot see that.
When I search for "SD-WAN" in the catalogue I only see 3 results:
Dhammike
Frequent Visitor
Frequent Visitor
Do you have partner access? Unsure this is due to access level issue.
Just checked again for you. I'm using SG dcloud and the POC tool is still available.
Please see attached. If you don't see it, could be access level issue.
Dhammike.
