Replace MX250
Hi Team,
I have MX250 in network but some reason want to replace MX250 with MX80.
As both are different models, Is it possible with cold swap move all MX250 configuration to MX80?
9 Replies 9
inderdeepsingh1
Level 11
Level 11
@inderdeepsingh1 , Thanks for quick reply.
I already referred that link, but it does not given any information about require changes in configuration.
Also link refer MX80 has only WAN RJ45 port and No wan SFP, for MX250 only WAN SFP and no WAN RJ45.
So will it move the WAN configuration correctly along with Security policy, NAT configuration?.
@suryakant.chavan : I am sure you are considering MX85 and yes it will move WAN configuration correctly along with Security policy, NAT configuration but you may need to evaluate the throughput you have now and will be after you are moving to MX85. All the features and the configurations remains the same make sure you have the same license for MX85 as well.
Cisco Awarded Blogs 2020/2021 https://www.thenetworkdna.com/
@inderdeepsingh1 , We are considering MX80 and for very short time round 3 to 4 months only.
Throughput would not be an issue as will have minimum traffic through it. Apart from that are you seeing any configuration related issue from moving from MX250 to MX80.
Thanks you,
Surya
ww^
Meraki Community All-Star
Be aware that mx80 can only run older firmware (14.56). And you will lose features you might be using , that where added in firmware release 15/16/17.
@suryakant.chavan : I would not recommend that to go to MX80.. @jdb1 said correctly.
ww^
Mx85? Mx80 is almost end of service
Philip D'Ath
The MX80 goes end of support Aug 30, 2023.
https://documentation.meraki.com/General_Administration/Other_Topics/Meraki_End-of-Life_(EOL)_Products_and_Dates
I agree with @jdb1 , if would be a bad choice to put such an old unit in.
Thats correct MX80 is not the right product for the change @suryakant.chavan
