Replication Issues | MTU Problem
Lloydie
Community Member
Hi Everyone,
Would like to ask if there's anyone encounter data replication from Cloud DB Server to Local DB Server (Linux Based OS)?
Default MTU of ETH0 of the Local DB Server is 1500.
We just need to lower the MTU of the Local DB Server to 1400 for it to proceed with the replication from Cloud DB Server.
Is there any by chance related to the Meraki MX 64/67 devices WAN MTU Configuration?
ww^
Meraki Community All-Star
What us the mtu of your wan router/isp
Is the replication using the autovpn or local wan breakout
IvanJukic
Meraki Employee All-Star
Hi Lloyde,
The default WAN MTU on MXs is 1500 bytes. May I ask why you looking to lower MTU Size?
Cheers,
Ivan
Cheers,
Ivan Jukić,
Meraki APJC
If you found this post helpful, please give it kudos. If it solved your problem, click "accept as solution" so that others can benefit from it.
