Router command
kumar_manoj
Community Member
Hi All,
I need a favour from all of u,is there any command on the router,through which we can see or monitor the movment of all packets.
Thanks in advance
Regds
Kumar
6 Replies 6
avillalva
Level 3
Level 3
Hi Kumar,
Look into the netflow technology. It will export information about traffic flows to a netflow capture application (such as Crannog). You will be able to see both layer 3 and 4 information so it can be quite useful.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios121/121cgcr/switch_c/xcprt3/xcdnfc.htm
If it's more instant, raw information you're after look into debug commands. Be VERY careful with them, they can bring down the router.
HTH,
Andres
Hi Avilava,
thx for yr reply, however need somthing more information towards this, if possible pls. sugest me.
Regds,
Kumar
Hi Kumar,
What specifically are you after? is it packet debug information or statistical graph type information?
Andres
Hi Avillalva,
Thx. for help and one more thing can i have yr personal e-mail id.
Hi Kumar,
post your email address and I will contact you.
Andres
manik.palekar
Level 2
Level 2
sh ip cache flow .........may this will help u..
