Security Reporting
ITPointeMan
Community Member
Good Morning!
Let me know if this would be better under the Meraki administration section...
I'm wondering what everyone uses for historical Cisco Meraki MX security reports?
I find the Security Center is very robust and great for looking at data up to a month old however it does not provide the functionality to go back further.
If I want to breakdown Summary Report information by quarter I can do that, but not so with the Security Center report. I do have regularly scheduled e-mail reports that come in on a daily basis but I'd like a way to view historical information.
I'm preparing a 2018 report, does anyone know of a way that the data can be looked up historically and/or can the Security Center data be exported to a third party application meant specifically for historical reporting and analysis?
Thank you for your assistance!
BrechtSchamp
Level 11
Level 11
Aaron Willette has an excellent blog post about Meraki's logging:
http://www.willette.works/meraki-event-logs/
Syslog can bring your logs into a SIEM:
https://documentation.meraki.com/zGeneral_Administration/Monitoring_and_Reporting/Syslog_Event_Types_and_Log_Samples
If you need more details about an incident, you should get them within the 1 month retention. You could setup alerting based on the priority score so you're triggered by your SIEM to do something.
You could also setup scheduled reporting via e-mail about the security events:
You could also use the API, but at the moment, it only has the client specific call, so that's very limited:
{{baseUrl}}/networks/{{networkId}}/clients/{{clientId}}/securityEvents?perPage=100
More info:
https://documenter.getpostman.com/view/897512/meraki-dashboard-api/2To9xm#de844141-5d03-4ba5-80f8-626f611db1ff
BrechtSchamp
Level 11
Level 11
More info:
Thank you both for your responses!
I do have scheduled e-mail reports for both daily and more recently monthly. I was looking to pull data for an end-year report and finding that difficult. At least with the monthly reports we can compile 12 reports into an end of year report in 2019.
I was kind of thinking this might be better looked at through the lens of SIEM and could be reported on through there.
I'll check out that blog post as well - appreciate the feedback!
Security Center logging is now down to two weeks. Are sales of Stealthwatch Cloud too slow for Cisco I wonder?
Philip D'Ath
Meraki Community All-Star
You could consider using a product like Cisco Stealthwatch Cloud, but it is a tad pricy so usually suited to larger organisations.
https://www.cisco.com/c/en/us/products/security/stealthwatch-cloud/index.html
As @BrechtSchamp says, this works by funneling the logs to it. Note that it can collect logs from other kinds of devices as well (including things like Amazon AWS), so is a more encompassing security monitoring tool.
