Small vent WAN interface control
tyshawn76
Level 7
Level 7
Can someone tell me why after all these years I don't have full control over my WAN interfaces? It really should take support to be able to set my DNS servers on the WAN when the WAN is setup in DHCP, also why is it I can't disable IPV6 on the WAN if I don't want to use it? Just the first ask THIS time has taken me two phones calls and multiple days to get this simple ask.
If you found this post helpful, please give it Kudos. If my answer solves your problem please click Accept as Solution so others can benefit from it.
Raphael_L
Meraki Community All-Star
I really feel you...
tyshawn76
Level 7
Level 7
This I honestly the ONLY router / firewall where I don't have these controls... I don't want to sound like old man fussing, but I don't want to keep calling support and wasting 20-60 minutes a pop for a simple feature I can control on a $70.00 TP-Link...
ThomasJohnston
Community Member
That’s honestly a pretty common frustration, and it usually comes down to how much control your ISP keeps over their equipment. When your WAN is set to DHCP, many providers lock DNS and IPv6 settings so they can manage the network consistently and reduce support issues on their end. It’s not ideal if you want flexibility, but from their perspective it avoids misconfigurations. If you want full control, the usual workaround is to use your own router behind theirs in bridge mode, assuming they allow it.
