Switch 2950 errors
mljevakovic
Level 6
Level 6
I got a message from my Catalyst 2950 (see the attach). Can somebody explain explain what does this mean?
Georg Pauwen
the following bug might apply. The ´workaround´ is to return the switch to Cisco and have them ship a new one to you:
CSCdv83336 Bug Details
Under certain level of traffic load, the (2950) switch will start logging the
following messages on the console:
SCHAN ERROR INTR: SRC=6 DST=5 OPCODE=20 ERRCODE=5
and after a few seconds, the switch will stop passing any traffic. In some
cases, the switch seemed still forwarding broadcast and multicast traffic,
which will cause STP problem if the switch has redundant link and is not
supposed to be the root for the VLAN, as both port will go forwarding.
The same error message has been identified in CSCdu87836.
An assessment of the impact
Unit stops passing any traffic.
WORKAROUND
Several units were returned by CISCO. The units were re-screened to the
latest test program, and failed the SDRAM memory test.
GP
