two GRE tunnels using same interface problem
dears
i need your help to create 2 gre tunnels using same source interface (serial ) !
the problem is the 2 tunnels aren't up when config them only one is up and the other is down
jamie.grive
Level 4
Level 4
Your GRE tunnels need to have something unique about them - I assume they must both also have the same destination address as well as source address?
The easiest thing you could do would be to use some loopback interfaces.
Is there anything else special about the GRE tunnel like IPSEC?
Hi ,
thanks for your reply
i've different destinations (loopbacks)
P.s there is authentication applied
the main issue now is that the down tunnel is stuck in IPSEC state !
Mohamed,
I had a feeling this might be going on - hense why I asked about the IPSEC.
You need to share the tunnel profile using the "tunnel protection IPsec profile shared" command
Note these restrictions
  • The              tunnel source  command on all tunnel interfaces using the same tunnel source must be  configured using the interface type and number, not the IP address.
  • All tunnels with the same              tunnel source interface must use the same IPsec profile and the              shared keyword with the              tunnel protection  command. The only exception is when only point-to-point generic route  encapsulation (GRE) tunnel interfaces are configured with the same  tunnel source in the system and associated with unique tunnel  destination IP addresses. Shared tunnel protection can be used when the  same local address between point-to-multipoint and point-to-point GRE  interfaces are shared only if the device is an initiator of the  point-to-point tunnels and not a responder.
  • Different IPsec profile names must be used for shared and unshared tunnels. For example, if "tunnel 1" is configured with thetunnel source loopback0 command, and "tunnel 2" and "tunnel 3" are shared using the              tunnel source loopback1 command, then define              IPsec_profile_1 for tunnel 1 and              IPsec_profile_2 for tunnels 2 and 3.
  • A different IPsec profile must be used for each set of shared tunnels. For example, if tunnels 1 through 5 use              tunnel source loopback1 command as their tunnel source and tunnels 6 through 10 use loopback1, then define              IPsec_profile_1 for tunnels 1 through 5 and              ipsec_profile_2 for tunnels 6 through 10.
  • Sometimes, it may be desirable to not share an IPsec session between  two or more tunnel interfaces using the same tunnel source. For example,  in a service provider environment, each DMVPN cloud can represent a  different customer. It is desirable to lock the connections from a  customer to a tunnel interface and not share or allow IPsec sessions  from other customers. For such scenarios, Internet Security Association  and Key Management Protocol (ISAKMP) profiles can be used to identify  and bind customer connections to an ISAKMP profile and through that to  an IPsec profile. This ISAKMP profile limits the IPsec profile to accept  only those connections that matched the corresponding ISAKMP profile.  Separate ISAKMP and IPsec profiles can be obtained for each DMVPN cloud  (tunnel interface) without sharing the same IPsec SADB.
  • Sharing IPsec is not desired and not supported for a virtual tunnel  interface (VTI) as VTI provides a routable interface type for  terminating IPsec tunnels and a way to define protection between sites  to form an overlay network.
  • Shared  tunnel protection can be used when the same local address between  multiple multipoint generic route encapsulation (mGRE) interfaces are  shared.
  • Shared  tunnel protection can be used when the same local and remote addresses  between multiple point-to-point GRE interfaces are shared.
Hello.
Could you please draw a diagram or provide a configuration from both ends, including routes per tunnel ddestination.
Routing could be an issue!
PS: if routing is not an issue, you may try to add unique tunnel key value per tunnel (be aware this will decrease MTU by 4 bytes).
