VPC Errors
jorgeborges
I am trying to configure 2 VPCs on a pair of Nexus 5010s.
The interfaces I want to use show as connected, but as soon as I create the port-channel interface with the "channel-group 123" command, the physical interfaces show as "notconnect" and the interface P0123 says "noOperMem".
I've tried deleting it and re-creating several times but the same thing keeps happening.
Any suggestions are greatly appreciated.
InayathUlla Sharieff
Could you do the following:-
1- shut down the physical interfaces
2- create the port-channel
3- unshut  the physical interfaces
Make sure you do this both the ends.
