WAN layer 2 encryption, possible?
avanzaadmin
Level 2
Level 2
Hi folk
I got a quick case here where an operator want's a layer 2, ethernet, trunk link between two sites to be encrypted. The endpoints are Cat 6513 running SXF5. Is there some way to encrypt using IOS, a Catalys application module or do I have to look for an appliance?
Fredrik
goncalo_gil
Level 2
Level 2
HI Fredik,
You have a few options.
L2TP has been around for a while.
You also have newer solution like Cisco TrustSec (MACsec) Layer which is based on the 802.1AE standard.
MACsec uses 128-bit AES encryption.
http://www.cisco.com/en/US/docs/switches/lan/trustsec/configuration/guide/config.pdf
I hope it helps.
Gonçalo
Hi guys!
Looking for a L2 wan point to point encryption solution, I did some basic research about MACSEC/TRUSTSEC, and I want to confirm with you what I have  observed:
-TrustSec is the Cisco implementation for MSCSEC (IEEE 802.1AE).
-TurstSec has been created for a whole solution of encryption, integrity, authentication, where the whole the network is speaking TrustSec.  Additionaly, TrustSec works together other sec devices and protocols (NAC, 802.1X, ACS).
-TrustSec could authenticate/authorizate a user or device taging his frame L2.
-Here a brief Solution Overview:
http://www.cisco.com/en/US/solutions/collateral/ns170/ns896/ns1051/solution_overview_c22-591771.html
-->Can someone confirm my perception that TrustSec is a whole solution for L2 encryption, authentication and integrity?
-->Do someone knows a solution (device or protocol) to encrypt a L2 wan point to point (a inter-site L2 trunk for example)??
Best regards,
Carlos Manzo
