x25 map ip command error
islam.omran
Community Member
Each time I issue the command "x25 map ip {ip address}{x25 address}" , I get the error "unable to retrieve configuration" .
a-vazquez
Level 11
Level 11
When error mesage is disaplyed simply reload the router once.Reloading router would solve the error many a times.In some cases they are fixed by upgrading the dram memory.This error may not be specific to the bug.
